hid lighting
lets try for two, the top switch is for high beam solenoid, i have it connected in parallel with the high beam switch on the truck , isolated with diodes on each, the orange turns on the hid from a fused full time hot , a second fuse off of the light side of this switch supplies power to the blue switch. this prevents the solenoid from being activated with out the lights being on. the next switch activates the hid lights in the fog lights, these lights were left over from my first try at installing the hid's the last switch is for additional back up lights, this gives me any combination i want with or with out the motor running, i had to remove and replace the front lense to install the projectors i tried to figure out a way to mount it from the back and could not come up with any thing. it's to embarssing to tell you how much time and cost it was on the first 06. my second one was only about $800 and 30 hour labor but i am happy with it. i changed all lights to led's they are all brighter than the oem
