Just bought a VW Jetta diesel (used)
Who sell's the most diesel's in pick-ups?
Question: PSD Upgrades
I found a great deal on a used VW Jetta GLS TDI 5 speed!
It has a few miles on it (60,400) but is in excellent condition.
Needed to get the wife out of the Yukon XL 2500 496 that
was being driven to work and back, 1,400 miles per month
at 12 MPG!:eek:
The Jetta ought to go about 4 times longer on a gallon of
fuel. They get about 45 MPG!
I figured the savings in gas alone makes the payment on
the Jetta!
Jetta Pics
-Chris
Chris, Neat car! I know that you will love it. I had a '80 dasher diesel wagon that I drove the doors off of for 19 years. I did some Mods,1. 6 eng, 5 speed out of an Audi 4000 diesel. The thing regularly got me 38 to 44 mpg and NEVER let me down!
If I could get my Wife out of her '84 MBZ 300 turbo wagon, I would put her in a jetta too. Chris
Good looking car Chris. You should get in the 50s with the Jetta. The jetta/golf get high mpg. The best I have got on my NB is 52. ? I started to get a Jetta. Drove the NB and bought it. Did not even drive the jetta or golf. I got about 38000 on it now. Remember when it comes time to have that timming belt changed. It should of had it done. If not get it done. I guess you already know about www.Freds TDI and www.vwvortex
Well I found out about the timing belt change requirement
AFTER I got the car home. :rolleyes: The dealership I bought
it from IS a VW Dealership! This is kind of a sore subject here.
The Jetta I bought is "Certified Pre Owned" and since the
timing belt is a MANUFACTURER REQUIRED mandatory new
timing belt at 60,000 miles, then they should have put in a
new one before they put the car out on their lot to sell! I
called the service dept and they said $450 parts & labor.
Monday morning I am taking it in and making a fuss.
The least they could have done is advise me that the
timing belt needed to be changed. Since they service and
sell them you'd think they would know better.
Otherwise I'm very happy with the Jetta. Looks GREAT and
this was the first red one I have ever seen, new or used.
I've been looking at them for a long time.
When my buddy sold his '67 427 'vette, he bought a VW bug- big change for sure. He never ran out of gas in the 'vette because he'd stop at every gas station. He DID run out of gas in the bug because he got out of the daily routine. Good luck on the new wheels!
Greg
vw diesel
I think that the vw diesel has saved me more money that any thing else I have ever bought.
I have a 81 and my brother a 83 and a tdi jeta also. Great fuel mileage an very dependable.
I wish that the engine was in a welder and a power plant. Use the web sights for info just like the TDR for the dodge.
lol Jim
Chris N5CWM, I would make a BIG fuss about the fact that they didn't change the timing belt before they put it on the block. I used to do them all the time (Timing belts) on the non turbo Rabbits and Dashers. They were easy other than having to have some special tools to time the pump and set the belt tension. Do they still use an injection pump as we old timers know it? If they give you a hard time talk the "Small Claims Court" thing, and call VW of America.
And So Goes The Battle!!:-{} Good luck and let us know what happens. Chris R
Time to throw a fitOo. :-{} . Make them do it and pay far it or refund your money and give them the car back. I would not drive it too much. I have heard some bad stories about what happens if it breaks. Go to Freds and post your problem.
http://www.tdiclub.com or www.tdiclub.com will get you there or maybe both. Another one that is just started several weeks ago is
http://texastdi.com/6/ubb.x
Not saying to do it but i put 75,000 on a belt on my Diesel Dasher wagon before I replaced it. You can usually take off the top half of the timing cover and ck the belt for wear and cracks.
Chris
I've been doing a lot of research at the TDIClub site.
Today I did take a look at the belt and it is worn but
not showing any signs of cracking. Still going to set
up an appointment to get it replaced. Might do it
myself if I can borrow the special VW tools to do it.
I posted some more pics, mostly engine and turbo
pics for you motorheads! ;)
I have some pics of the fuel pump too. It's a Bosch
unit that looks mechanical.
TDI Jetta pics
tdi belt
I had a 1980 rabbit p. u. diesel since new,sold it last year,had 300,000 plus (many head gaskets and one o-haul). did all work myself and finally body was rusting out. got a 83 quantum tdi and o-hauled it and is running good. the access is a lot worse because of inline engine with many pulleys and belts on front. '
If you take a chance on the belt on one of these and it breaks it will destroy the engine,Ive seen it. blows the cam right out of the head, and hits the pistons.
If you do it yourself,make sure and double check your crank position after as sometimes the crank moves when you tighten the idler and a little movement can make a big difference.
good luck
cliff
Chris, what kind of a digital camera did you use to take those photos? They look great! I am in the market for a new digital camera?
Chris last picture. Have you taking that hose off the egr valve and looked in there?Get the egr mod done with the vag-com too. Run that hose that comes off the breather to the ground and cap where it went to. They say if you do this you want have any problems with the intake so I did it. Time will tell. Clean looking car/engine.
It is a great car. I have a 2000 jetta 5 speed. Mine is red to. I have 61. 5 K on it. I commute from Albuquerque to Santa Fe and back everyday. Last week I got 50. 6 MPG. That's at 75 MPH with the A/C on and 1000 foot evelation change. Use the best synthetic diesel rated oil, adapt the EGR flow rate and do a CCV modification. Buy or find someone in your area with a Vag-com and the Bentley CD. Do the belt replacement yourself if you can't get the dealer to do it. It's not hard, but you need to invest in a few special tools and get access to a Vag-com. It's not worth risk to go beyond 60K on the original belt. If it breaks you'll mash your valves and pistons. Look into your intake manifold at the EGR valve. It will most likely be clogged up. Clean it up and do the EGR and CCV mod's and it will stay clean. Search Fred's. There are lots of TDI owners in Texas to help you.
Successful day
Took the Jetta back to fight for my rights!
I went in and asked to speak to the used
car manager. Gave him my side of the story,
which is basically that I bought this car that
was "VW Certified" with an extended 2 yr
24,000 mile warranty. Told him I bought the
car so my wife would have reliable transportation
to and from work 5 days a week, 1,400 miles a
month. I was not informed that the timing belt
would need changing while I was buying the car.
(I did find out on my own after I got home and
did some research. A call to the service dept gave me
an estimate of $450 parts & labor. ) Told him
that I felt since this was a VW dealership they
should know a TDI belt has a 60K mile limit, and
mentioned it
to me pre-purchase, at least so I could arrange
to have it replaced and arrange to have the cost
added to the financing.
I was not amused that I would have to lay down
an additional $450 before we could start driving
the car without risking engine damage and/or being
stranded on a busy highway.
I also had an issue with spare keys. They told me
that the one key and keyless entry fob was all
they had when I bought the car. Today I politely
demanded they search for the other set of keys.
Lo and behold, 10 minutes later (three salesmen
and the manager) searched all of their key boards
and found two more keys and one extra keyless
entry remote!
Thank you very much! :rolleyes:
That alone saved me over $100 getting those
replaced.
I felt better after that and when the manager asked
if I would accept splitting the cost of the timing belt
change at their cost ($360 or $170 apiece) I felt
that was fair enough. I did not have any bad
feelings against the salesmen, so I was not out
to get back at them nor did I have any desire to
demand they give me my money back. I really like
the car.
So I have a "We Owe" from them on paper!
And a total of three keys and two remotes.
Sure I could have fought harder for them to pay
100 %. Maybe I should have. But that was my
plan until they found the extra keys. :cool:
emarsh,
The pictures were taken with a Sony DSC-S75
digital camera with 3. 3 megapixel CCD. Found it on Ebay for
a good price last Christmas. Also try Buy.com and the local
store Best Buy.
Get at least a 3+ megapixel. There are some reasonably
priced 4+ MP cameras out now. Sony, Olympus are good
namebrands to start with.
Ischultz & Run8ram,
I bought an intake manifold gasket today along with some
oil and fuel filters. I heard about the VAG-COM but have yet
to find one locally. Once I do I will do the EGR adaptation
mod. And the CCV mod too. I have seen some pics of TDI
intakes that are so plugged up there is barely enough room
to stick your finger in the remaining space! :eek: Thanks for
bringing those issues up. I found out a lot reading the
TDI Club FAQ.
sdalton, I plan on adding a fueling box soon. Hope
the clutch can take it! Going to add boost and pyro gauges
too.
New timing belt has been installed!
Made an appointment with Demontrond VW on I-45 North
near Greenspoint mall. Finished it by 5PM that day.
I called and advised them I wanted the -119M belt
and -243N tensioner. Out of curiosity I checked
the belt after I got it home and it is the new 80K
belt. Whew! I am not sure if they changed out any
of the engine mount or fuel pump bolts.
Tonight I chaged the oil & filter. Biggest PITA as
you all know is the plastic engine belly pan.
Everything checked out OK. Refilled with Amsoil
15W40 synthetic (AME-04) and a VW filter.
I bought two fuel filters the other day but did
not bother to look in the box. They are for a
gasser! [roll eyes] Gonna have to take em back
and get the right ones. I did mangage to drain
the fuel filter a bit from the bottom petcock.
61,208 miles and counting! :D
