Ok, no offense, I'm with you on your explanation. Am curious on a couple of things however. One being kicking it out of 4x4. Do you generally kick it out during the run or soon as you cross the 1320'. Just curious cause if you kick it out at the end be sure and let off the go pedal, kick it out, then hit brakes otherwise you will be power braking. Second, I am not familiar with ATS stage 5 but is that all three billett shafts? If not 20lb, launches will break something in the transmission soon. As far as temps, I have not pulled the head on mine and I don't intend to do so to expose any cracks that might be there. I don't wanna know. No leaks to I am not messing with it. I just left the head on and replace the head studs one ARP at a time.
Regards,
Roger
