Amazing that there is so much copper in your houses plumbing.
The grounding goes like this. Ground Rod, water pipes and gas if there.The line that I'm having trouble with is that heavy copper. This house also has the electric service entrance grounded to the copper pipes instead of a ground rod. This is the line it is tied to.
Coincidence?
If I were replumbing these days I would probably go with Pex Tubing. RV's have been using it a very long time and newer houses also.
I’m not much of a plumber so last time around I went Pex. My only complaint is the fittings reduce the effective pipe diameter. Next time I’ll run 1” instead of 3/4 feeders.
Since I'm going to do an entire new run up to my kitchen for the sink and dishwasher which feed off the same lines, what size would you recommend?
Yeah plumbing is replace everything unless it is fairly new.One of the few lessons I’ve finally come to understand about plumbing is if you have to touch it while doing a repair, you need to buy a new one. Every pipe, valve,drain, or faucet I’ve ever tried to save always failed and cost me extra time and money.
I'm usually right up on my vehicle maintenance, take care of a vehicle and it will take care of you....etc..
But after a whacked out year of drama, deaths and other things I find that I am behind on care and feeding of my vehicles...
Pulled the wifes van in for a service, thought it sounded a little ratty when I started it. 3.3 L with 112,000 miles on it.....sitting in it listening and I also hear a noise in the front heater blower motor.....
Dig out my records......somehow it never has had a spark plug change...good place to start as any....
Bought plugs for that (bought the OEM spec, why wouldn't I) and will change those today...
Car sounded ratty on a cold start last week, dug out the records that came with it and guess what?? That's never had spark plugs either!!! 105,000 miles and 12 years old.....bought plugs for that too and will change them today as well. At least those have a 100,000 mile change interval....
Will take longer than the van as I have to remove some stuff to get the rear plugs out.
I am ashamed that I missed that but one can only deal with and do so much....
