Re-Test results with and without pantyhose "pre-filter" (again, 2 runs in opposite direction with each set-up, 0-95mph, with cool down between tests):
With "Pre-filter" - 1st run-1344, 2nd run-1351
Without "pre-filter" - 1st run-1344, 2nd run 1344
Obvious conclusion is that the pantyhose offers very little (effectively no) restriction. Think about it - this filter is probably 2X the diameter of my wife's leg, so this thing is stretched pretty thin. You can see through it very well.
First off, please don't think I'm being negative about anything or anyone. I bought it, tested it to see the performance, and posted my results. I've tried to keep the testing very consistent. If anyone has any comments, tips, etc. , please feel free to share. I'm in this to lower my EGT some more, nothing else.
Rob, My thoughts exactly. Wrap one of those pre-filters around your face and do a few 100yard dashes. Do the same with the pantyhose stretched thin. I think I can guess which is harder to breath through.
Mediccummin, Sounds exactly like how mine fit, PIA to install, hose made oval instead of round (this could contribute some, but not real distorted, so I wouldn't think much). What was your third set-up? 1 was Psychotty and another was 0880 w/ prefilter only, right?
Bill, I tow very little, so I haven't tested it towing. Your statement may very well be 100% accurate. But we haven't heard the conditions on all these posts about the Psychotty. I guess we need to hear from all of the other guys that saw a big difference - what were the exact conditions? That's also why I asked, what was your exact set-up previous to Psychotty.
Clark, I understand what you're saying and that may be true, but I'm still comparing two things on an equal basis. Everyone has said the same thing about the stock set-up being marginal for mildly upgraded trucks, and that the Psychotty flows more than the stock box. My tests simply say that, in my test conditions (which are based on the reason I got the Psychotty), the Psychotty is not as good as a K&N in the stock box with the "snorkel" removed.
About a year ago, I read a post by Joe D. talking about pulling out that "snorkel". At that time I had 275's, PE, and K&N in the stock box. I could pull the filter minder down to 50%. I pulled the "snorkel" and haven't pulled it down since. That thing is definitely the 1st big restriction in the stock setup.
Right now, I'm still scratching my head.
I want the best possible (cheap) intake that I can come up with. I'll either perform Bill's "Sorry Scotty" mod's to the stock box (since I already have the hole in the cowl) and replace the snorkel (that way all cool air is pulled in), or I'll cut a hole in the side of the Psychotty and connect it to the hole in the fender. Or both, but a few guys have asked about buying the Psychotty, so I hate to mangle it.
Any suggestions???
