I drove a buddys truck today that has the Adrenalin on it and it seems to have a "Dead pedel" anywhere past half throttle from PL03- and up
He sent it back to Quad and they said it was put on a truck and it ran fine, well its not on his what gives???
Michael
sounds like he has a problem with the VP bypass solenoid. it would only affect it at higher power levels. when the box comes back try it on a different truck to be sure. I could meet you at "coffee night" and swap boxes to test.
Is he running an aditional timing box like a Van aaken or smarty with timing? Sounds like the truck is overtimed.
Quad adds alot of timing, but the way that he brings it in is the biggest thing. If that truck has big injectors, they will add timing by themselves, then if a bad map sensor is added to the mix+Adrenaline timing... . anyone of these could be his problem.
YEP! fuel pressure sender AND oil/trans temp AND EGT probe! you will not be disappointed!I just ordered one i can wait to get this thing! I like my comp but this thing sounds pretty awesome! I'm also wandering if it comes with a EGT probe or any other sending units?
Graphic man- try 2019 as you have mach 6s.
Bad serging (bucking and jerking) at 60 mph (light throttle) with the ADR2000 tune on all PL settings... so bad i have to un-lock the converter to to get it to stop
anyone else have this problem??
Does it also seem to have a dead peddle???
Michael
no i don't get that at all..... maybe your APPS or VP ??
yeah it was the VP, it went yesterday
Michael
