JCleary said:Hahaaaaaaaaaa!!!!! Got mine yesterday. Now, if I can just get the time to install it...
You only need about 10 minutes to get it installed enough to give it a try!
tomeygun said:Funny thing is that it does not usually happen this way...
With the TST, I think it took a little longer to get rolling, and it had a few glitches before it was smooth and error-free
The quad box seems to be perfect right out of the gate (due to large beta testing??)
LightmanE300 said:Tomey - did you really need 3?![]()
tomeygun said:I thought EVERYONE stacks two or more modules now-a-days?:-laf
Diesel Nut said:Also, question - Are you supposed to run a boost jet on the turbo? I still have mine on from the edge way back when and don't know how that affects it, good or bad? Anyone? I know Quad must be lurking around here somewhere to hear what people think of his latest thingymajig.![]()
tomeygun said:one things for sure... That elbow is the devil!!! With the TST, that elbow will let the turbo spin to like 50+ lbs before it opens the wastegate, Heck try blowing through it, you almost can't!!
I would take it off, and get with quad about what elbow to run
Just stay near or under 35 lbs, and you should be fine
DWestfall said:Well I got it today! Iwas strapped for time so I havent mounted the holy crap-o-meter knob(thanks Tomeygun). Just plugged it in cranked it all the way and Holy Moses! I never dreamed a over 7000 pound vehicle can do pwer slides. Man this is fun! I have a few observations though:
1) on 30 it makes my truck feel the way I think it should have felt from the get go.
2) on 60 it is the equivalent to the Edge EZ on 80 HP setting.
3) on 100 you can smoke the tires at will from a dead stop. All through 1st part of second and a little in 3rd. Just driving down the road normal driving the engine is noticebly louder.
I am totally satisfied! Thanks Quadzilla!
Here is another observation: Just before I installed it on mine I put it on my buddies 03. Now he has the HO 3:73 gears and short bed. I was not impressed with it on his truck. It was no where near the monster my truck is. My truck is an 03 SO 4:10 LWB The same thing happened when we put the Edge EZ on his and mine. Mine ran better than his. It was night and day difference. Can anyone explain why this is? He has 50 more HP from the get go! His truck is definately stonger running than mine when we are both in stock form. His truck is louder in the cab (79db @73 MPH) than mine (72db @ 73 MPH). Mine is Laramie his is SLT. Can this be explained? Again, hats off to Quadzilla!
Diesel Nut said:Quad - is there anything on the actual module that tells you which program you have?
