Removing power window/lock pod
Firefighter Union Sticker on Front Cover of 28
Gas Pedal Noise!!
Anyone care to reveal the secret to removing the afore mentioned pod from the door panel? After reading that it is an integrated and unrepairable unit, I am reluctant to experiment.
Thanks
It pops right out. The switches and plate are are all replaceable. Anyone know of a conversion from electric to manual windows? I would like to keep my electric locks, but hate the electric windows. I would like to keep the pockets and cloth door panels, though.
1996 White, Extra-cab, 4X4, 5-speed, 4. 10 Model 80 rear, Laramie Pkg, Rickson Truck Accessories 19. 5" wheels with Michelin 265/70 XZT load range 'G' mud type tires, 4" turbo-back full-straight pipe exhaust with through the bed stack, Mopar brush guard, K&N RE-0880 air filter,"Psychotty Air", removed turbo silencer ring, Banks Boost & Pyro Guages (pillar mounted) 'tweaked' injector pump (cam plate all the way forward, AFC control run all the way in), well over 120k miles, lots of GOOD, BLACK SMOKE!!, Rollin'-S 25-foot, 10 ton flatbed trailer, with Vacuum/Hydraulic brakes, 16. 5" tandem dual Dexter axles.
Once you get the switches out, take them apart and clean them. Use 400 grit sand paper and clean the contacts, then put just a dab of silicone dielectric grease on all the contacts. This works, I've done it to mine and since I started putting grease on them, I haven't had to redo. Good Luck!
