2nd Gen Non-Engine/Transmission Repairs for the DEATH WOBBLE
2nd Gen Non-Engine/Transmission wheel bearing
2nd Gen Non-Engine/Transmission Track bar what the !!!!!!!!
Death wobble...
The best permanent fix for the death wobble after making sure your front end is tight and the bushings are good is to take the truck to an alignment shop that knows what they are doing. Dodge put way too little caster in the front end from the factory. Have them increase the faster to 2. 5-3 degrees. I did this to mine after replacing the loose parts and the truck is still solid as a rock after 60k miles. Best steering mod you can do.
Proper service (OEM trackbar gone. . ), alignment, and get rid of that Y configuration center link that's on the 2nd Gen's... .
