While towing I limited mine to 1300 deg. Racing it will barry the guage 1500+ for just seconds. On my 12 valve the EGT are never a problem until I rev it over 2600 RPMs. Even towing a back hoe up a 5% grade the corners where the problem not EGT. Up that guage I reach 1100 deg max.
It's just like a cutting torch you can hit the metal with that great heat for seconds w/o cutting it but if it dwell there too long it cuts through it.
EAT'M UP
97 2500 Club 4X4 3. 54, Forrest Green/Driftwood, LSD 5 speed, & Psychotty Air System, TST #11, 370 HP injectors, timing at 16 deg. , 16CM2 housing, AFC spring kit, TST EGT gauge & 0-60 boost gauge in A Pillar, Cat-be-gone, 4" Dynomax Bullet muffler, Crome 4" turn down, 2 Electric Fans, One inside/ One out front, AmsOil Through out, Geno's trans filter kit, AmsOil Bypass system, Lund Winter front, Leer Cab Level Shell Driftwood , 255/85R16, South Bend's Hypo Clutch*NRA/USPSA member and proud of it*
[This message has been edited by drawson (edited 04-04-2001). ]
