1st and foremost, get a pressure gauge.
Best to install one permanently.
But of course you can install a test gauge and take it for a ride.
The original Cummins position was. .
Stock truck, good LP, at WOT on the road, 10lbs pressure or more is a good LP.
The dealer will tell you it's based on volume, so that even zero pressure is ok, as long as when they do a volume / time test in the bay it's ok. . THATS pure B. S.
Cummins now has a kit out for buses and trucks with the ISB that has a Low Pressure warning switch that kicks in 3 - 5lbs... warning that the LP is bad.
I still believe in the 8-9lbs and it's time to replace.
10 and above, all is good.
It makes sense on a stock truck, stock lines.
I've heard other possible problems with dead pedal, can't remember them all.
But to rule out the LP, get a pressure gauge installed so you KNOW what's what with your LP.
My VP44 has lived through a bad LP that was producing 5psi @ idle and zero @ WOT and working hard. I foolishly did not have a pressure gauge. The burning smell from the VP44 is what clued me in. Power and pedal were fine, as was starting.
After the LP was replaced, was at 15psi idle, and 12 psi WOT and no more smell from the VP44 when working it hard and planting the pedal to the floor for long periods of time.
