Yes, I know of several people who have done this... I'm not 100% sure of the particulars (exact years, makes, models, or the conversion)... but IIRC, early/mid 90s F350s with the D60F balljoint front axle (SRW) are the parts source (the later models have unit bearings, so make sure of what you are getting)... then everything from the knuckle out is swapped including the stub shaft... keep in mind that if you have four wheel ABS, there is no provision for the front ABS sensors.
I believe you can find everything you need to know at PavementSucks.com ... just search that site a little bit.
steved
