2 gauges or 3? What do you think...
Cummins Air Pump
IDEA: Protect your bed with a horse mat.
I'm about to add some gauges so that I can start Bombing. I have a 95 with a 5 speed. Since I don't have a need for trans temp, should I go with just boost and EGT or should I add a third to monitor??? What do you guys like?
Soon I will add TST #5 plate and bigger injectors. I already heard, there's a new clutch in my future. Already have aftermarket K&N Air.
Thanks in advance for your help.
Bill Littlefield
'95, 2500, 4x4, 5sp
You might as well install a 3 gauge pillar now. Then you can put a fuel pressure or oil temp gauge in. Which most people ultimatley end up installing anyhow.
I agree. I orginally bought the two gauge mount and ended up having to buy the three... boost, EGT, and fuel pressure. I wouldn't want to be without any of them.
98. 5 2500, 24v, 5 speed, QC, 4x4, 4. 10 LSD, short bed, Line-X liner, tow package, camper suspension, Westin nerfs, camper shell, TST PowerMax Competition, 275 RVs, Psychotty air, HX-40, 4" straight pipe exhaust, Southbend clutch, ProComp A/T 305/70/R16s, EGT/Boost/Fuel pressure pillar gauges, Grover air horns... Love my Cummins, no love for Dodge
Without a doubt- take three. I wish they made a four #ad
but there isn't enough room. I do have the need for the trans temp and now am left trying to figure out a good clean spot for a fuel pressure guage and maybe an oil temp..... decisions, decisions.
Kevin
1996 Ram 2500 4x2, Auto, Banks Power Pak, FABTEC 2" lift, Rancho RS9000, 265x75x16 on custom wheels, Line-X, Toolbox, Westin Steps, Lund Stainless... ..... More to come
Go with a dual gauge (like SPA's) and you can get 6 gauges in three holes or four gauges in 2 holes. They are spendy but they are nice.
John D. Rathert Jr.
01 2500 Forrest Green Sport SLT+ QC LWB 4x4 Auto 3. 54 rear end with all options avail. DC Nerf Bars, DC Grill Guard, DC mud flaps, Line-X bed liner, Leer 160XL Topper, Power Edge, EZ Edge, SPA Boost/EGT Gauge on pillar mount, DTT's tc/vb combo, 275 RV injectors, DD 4" Exhaust and a KN RE0880 where the air box use to be. Fuel Pressure gauge, SS fuel lines and lift pump relocation on deck. See My Truck, Dads truck: 98. 5 3500 SLT QC LWB 4x4, Brother Truck: 92 W250 SLT CC LWB 4x4 (Dads old truck) Winter fun - 2000 Skidoo Summit 700
I am my own warranty station.
JR2 has the answer, SPA's all the way! I personally don't like more than 2 guages on the pillar, SPA's let you monitor 4 things instead of just 2.
99 2500 QC 4X4 AUTO SB 24V LARAMIE SLT 3. 5 LSD 285-75-16'S SPA Boost/EGT Rancho 9000's Everything but leather NRA Member Great Lakes TDR Member
Dkevdog
I installed my fuel pressure gauge in that useless square hole above the AC controls. I removed the dash bezel and the square hole comes out with 2 screws. I got a piece of 1/8"plastic larger than the square hole in the dash bezel, cut the right size hole in it for my gauge, painted it flat black and used contact cement to glue it to the back side of the dash bezel and it looks like a factory install.
97 SLT Laramie CC 5spd, 3. 54, Ranch Hand front and rear. Gauges, EGT, Boost, fuel pressure, oil temp,indash CB, custom switch mount-6 switches BD brake extra fuel tank 45gal. Oh oh dang cat fell off, took the muff with it. Member NRA/USPSA
Thanks guys. I'm serously considering the dual gauge from Westach for boost and EGT. I read the product review and it sounded real good. I also agree that if I go with a dual pillar set I will probably end up making it a tripple later. Hence my reason for the original question.
For those of you who recommended fuel pressure, I read in another post earlier this week that it isn't advised to continously monitor fuel pressure. I assume you guys aren't having any problems and the gauge doesn't bounce all over the place?? Do tell.
Bill Littlefield
'95, 2500, 4x4, 5sp
Bill,
I've had the Westech Pyro/Boost from Geno's in my truck for the past 2 years and have had zero problems with it. It's in the dash where that idiotic square hole used to be. But, like you, I'm looking to put something on the pillar.
'99 Ram 2500 QC 4x4 Shortbed SLT A/T K&N, Westech pyro/boost, Line-X bed liner, Rancho 9000 shocks, Midland CB,285/75. 16's w/Abbott ERA, JRE 4" exhaust & JRE Stage I injectors Horton clutch fan
I too have Westach gauges, no problems at all. I have the 3-pod on order from Geno's with Westach's new fuel pressure gauge, hopefully in soon. Westach's look real good with the stock gauges, just put the green cover over the lights, makes the right look. So, that will be a total of 5 gauges in 3 holes - transmission temp, boost, fuel pressure and two EGT (switched using the combo gauge). I'm pretty sure no one will ever come out with a five gauge pod! Would have to extend into the fenderwell!!
'99 2500 4X4 QC/LB Blue Box, 14cm2 housing, RS9000's, VelvetRide, Line-X, M/T w/Goodyear 305/70s, boost/EGT/transmission temp, transmission pressure, AMSOIL throughout, BD valve body/TC/PressureLoc, Bosch 275 injectors
Don't be fuelish, go diesel
