Engine/Transmission (1994 - 1998) 96 12valve interminetly loping at idle
Having issues with my 97 12 valve. I have checked the fuel pressure and it is good, check all hoses all a fairly new. This only happens at idle otherwise runs like it should. It will idle and then just start loping like it has a big cam. i can tap the throttle and it will stop but i can also tap the throttle to make it start loping. Idle is set at 850. I can also crack the injector lines and will stop to. Please help. Have had diesels for awhile but just joined the site and i love it!
Does your pump hsve a buffer screw? If so loosen lock screw nut and turn in 1/4 turn and retighten lock nut.
