4k miles with fluid damper. ( 3500 miles with TC ). my impressions
Made quite a difference in transmission ' growl ' under load
( 6 speed ), Changes the vibration noise from a low freq to a quitter hgh freq noise ( I think ) may be just hearing the engine
noise which was masked by the trans noise. ,
Much quitter at road speeds.
Do get some low rpm growl from the trans when it warms up,
just coming after clutch engage at low rpm, but no way like before fluidamper install... . Should help longivity of trans,
Do have some rattle when shuting down, ? clutch or dual mass springs??
When unloaded," NICE": with the Smarty on fuel saver and the
fluidamper, Feels/sounds like a sports car,
Install was easy, except torquing the bolts to fluidamper specs.
Tryed to use trans in gear to torque bolts, clutch slipped before
torqued to spec ( should have used direct gear instead of 2nd )
my mistake, did get above 130 lbft, should be enough for
for std hp, ( did not pin the fluidamper )
Did/Do have 1 concern, right after install, I had some Black,
gooey stuff stuck to the track bar, looked like it dripped from the fluidamper ( not sure ). been checking since, no re-occurance
Bottom line, It works... . as advertised... Great for std shift. .
