weight
Ultimate towing rig!
Towing heavy w/ stock hitch...
Hi folks>
Comming home from work today, I thought I would pull into a local truck stop and weigh my truck and trailer. I been complaining about the truck not pulling like it used to.
Was I supprised to see the weights. The front axle was 4260lbs, rear--5000, and the trailer 10,700 lbs. Combined was 19,960. This may not be much to some but that is 2000 over my RV fiver. Now the truck weighs 7460, with a full tank.
My point being, I felt my rig was going sour and I was loading it up. Now I wonder just how much will these Cummins will pull. Talking to a diesel mech. yesterday, he said these engines are de-tuned like you won't belive. If they were not the torque would twist the frame into a "barber pole". HVAC says 600 HP, how does it take it?
Well I guess it's time for 370 marine injectors and fuel plate. We'll see.
Take care and happy towing. #ad
Preston
Thompson #ad
96 3500 Black 5 speed turbo diesel, SLT, with US Gear overdrive, Rhino liner, Reese 15,000 lb. fifth wheel hitch, US Gear de-celarator exhaust brake, muffler elimination kit, Amsoil lub. , with other goodys on the way.
TT
Your are still a light weight!!
As i've grossed 25 k and a few times over 32k thru the hills of va. -w. va. I-77 Ky-NM. ca. -id nv. ia, factory turbo-inj-and fuel plate, (adjusted)and not had a proplem blowing past the big rigs except when the outside temp's get to 94 deg,then you have to shift out of 5 th or 4th 100dg to keep the rad under control,needs more cooling cap for these temps/weight.
This same eng is put in Fl 50's & 60's and is the main stay for Ford F 600's,pulling 54k
in there case it is set around 265 hp.
96-3500 SLT EXT. CAB AM/FM/CD-RINO LINER. D-CELERATOR EXH. BRK-RED LINE VAC. OVER HYD BRK CONTROL- AIR BAGS W/HVY DUTY AIR COMP. PUTCO S/STEEL DEEPBOARDS FRONT TO REAR. REESE 20K 5TH WHEEL & GOOSE -REESE 20K HITCH BELOW W/17K RECEVER. CLEAR COATED & SOUND DEADINGING &UNDER COATED 5 SPD/W 4:10 MCHLN'S 235/16'S UNIDEN PC76/WEATHER-WILSON 1000 MAG MOUNT ANT. 4 WHL ANTI LOC BRK SYS.
