Altexp, The idea is to stay below the GVWR.
Airbags, etc. will not increase the rating. I own a 3600 lb. Lance and it is tough to stay under the 11k lbs. The weak link with my setup is the truck brakes. I nearly started a fire on the front pads while in Nova Scotia.
I have the air bags, and all the other stuff too. My RR air bag brakets are all bent up also, as someone mentioned above. I don't use the bed liner on long trips, the camper does slide around. I use a rubber mat. I'm not sure what happens when you are operating an overloaded vehicle and are involved in an accident. I know I can't afford to find out.
I'm too am sure an overloaded Dodge is okay coming from the local Home Depot, but those people don't belong on the highway.
Ron
98 3500 QC 4X4 Int Blue, 6BTA5. 9, Auto 3. 54 LSD, PIAA Pro90's, RS9000's, Tonneau, Running Boards, 5K Air Bags, Hadley Air Horns, EGT/Boost/transmission Temp Gauges, Cobra / K40, Valley class V, Bugflector II, Bedliner, Tow Hooks, Cup Smoothie, Meg's turn-down tip, SS Fender Flares... .....
99 Lance 1110 Slide-On Truck Camper
Ron
