lethal injection said:I just ordered mine. What differences will I see over my edge with attitude? Should I keep the edge and run it with it or sell it?
Yea, what he said.
KellyP said:I have one and HOLY ****! WOOOOOW!
Yo Hoot said:Simple question. I hope I'm not asking too much here as I could not find the answer to this on the Smarty or the vendor websites. I asked this a few posts up but no answer.
How do you change power levels?
lethal injection said:Will it be safe to leave the edge on setting 0 (stock) and use the smarty or should I disconnect the edge?
MR4WLR said:Yep![]()
I got to use one on loan this evening at the drag strip :--)
with my TST and EZ stack I was running 15. 1
Upload Smarty and turn off TST and EZ = 14. 43
next run was 14. 31, my previous best ever was 14. 41 but was unable to do it again last weekend or tonight.
So the next round I decided to add a little TST into the mix, 2X5 (single program)
Pulled off a 13. 949
next run, backed it with a 13. 950 Oo.
this ain't no built auto, 6sp with 35" tires wieghing in at 8400 lbs![]()
Bob Wagner said:no need to disconnect, try smarty alone to start![]()
Bob Wagner said:simple 2 minute ecm tune and you are done. smarty plugs into the obdII port and is undetectable when removed![]()
RobertP said:so the key count is not altered, or the country?
Bob Wagner said:nope. this product is done right
JPereira said:Corey,
If you do the math the 13. 9 runs are around 611HP
Previous best 14. 41 would be some where around 550hp
I am curious if you had ever dyno'd your truck to have a baseline of what you had been running.
I am saving up my Bomb funds for a Smarty... .
Jeff
Big P said:You cannot change HP levels on the fly. You need to download new/different software. I like my Smarty on 60HP without timing and use the TST to dial in more power when I want it.
Bob Wagner said:Well the 60 HP program yielded better mileage gain .
stock mpg towing total 17K 11. 2mpg
60HP program 14. 7 mpg
30 HP program 12. 9 mpg also running high speed
egt reduced 100F+ over stock
